saburai
Hi Gang! Like it says, I hope that somebody whose "massaged" their firewall to fit the banks downpipe could post a picture or two. TIA!
I cut the tab off my zf for even more clearanceHere is a picture from underneath the truck. You can see the cuts I made in the seam with a reciprocating saw. I then bent the seam out of the way where the exhaust pipe needed to go.
Here's some pics from my old truck (ATS install with 3" DP).You must be registered for see images attachYou must be registered for see images attachYou must be registered for see images attachYou must be registered for see images attach
I used a complete 4" stainless Diamond Eye kit for 1999 powerstroke which includes a 3" DP. The only piece I had to mod was the DP and it was slight. Think I made a small pie-cut to create a different angle off turbo then welded it shut. Kit designed for Powerstroke exhaust fit perfectly even the hangers.
my latest one, i didnt cut the pinch weld at all. a hydraulic jaw on a port a power does a wonderful job of just pushing it backwards and folding it around. cant get any pics though, wont be able to see it with it all together.
