Lift pump replacement time
Alwaysreadyrob
2002 7.3 POWERSTROKE 4x4
OAKHURST CA
Its done, bypassed the mechanical lift pump and wired in an electric fuel punp 5-7 psi.
Hot wite to glow plug relay hotwire onthe constant side... pump bolted to fenderwell , its plastic so will see how she faires...may have to move but naybe not.
Kevin 007
Full-floater
Nelson BC Canada
If its mechanical lift pump why not just block it iff and go electric?
Well....the main reason I don't go electric on 94-97 psd's is because they don't seem to have the air intrusion/drain back issues that the idi's did. Or at least not as common. So I like to keep non electronic things in service whenever possible but with the idi's man sometimes its tough to justify staying with a mechanic pump.
olsen726
