Well, today as I pulled up to a stoplight, my truck decided to die. got it started by the time it turned green, so I skipped what I was gonna do today and decided to pull the front tank.
I indeed could see how the front sender would come out of the tank still in the truck with little effort. I debated on doing it, but I wanted to look inside the tank for gunk, and pull the skinny hose out of the filler neck so I could actually pump fuel into this thing.
Dropping the front tank took minimal effort, and in less than 15 minutes it was on the ground.
Upon pulling the sending unit, it appeared fully intact.. Why was I getting air at 1/4 tank?? Upon further inspection, I believe the diaphram a little ways up on the shower head is to blame.
I had some good fuel line in the toolbox so I measured it up, and cut dimples out of the bottom of it.
Next I removed the hose clamp under the bed holding the filler neck on, and the three small screws by the filler cap and wrestled the filler neck and hose out.
A nice good pull on the black tube popped it out of the filler neck, problem solved. Put everything back together and the truck runs and drives good. I'll be pulling the filler neck out of the rear tank soon and removing the black tube from it as well.
Job wasn't as bad as I thought it was gonna be, I was done in less than an hour, and I wasn't in any real rush. The back tank looks to be a PITA tho..
