Mine is leaking right between the two cast iron pieces. Is there a seal that can be replaced? Is this something bad? I seem to remember someone saying they all leak some, is this right? Mine is a rebuild unit.
Thank You.
Thank You.
ez-
there's four bolts that hold the two halves together. tighten them up a little. I've found that loose bolts are ofter the problem there. Now if it's leaking out the back pushrod or the front area, you have a real problem there.
