Jamie
Finally took the plunge and got a Stanadyne return line install kit. It was super easy to install. I went ahead and cleaned up the valleys on the intake before firing it up for the first time after installing the kit so that it would be easy to spot any leaks. Everything looked good upon inspection while at idle except for one thing. The injector behind the furthest one ahead on the driver side was clearly leaking. It was kind of bubbling from where it meets the head.
My question, what is the best way to fix this? I did attempt to snug it down, to no avail. Shall I install a new copper washer?
Thanks in advance,
Jamie
Thanks in advance,
Jamie
