Lazy man fuel switch repair
Oldschool280
Hudson valley
My fuel switch works for the feed, but the return is ng. I ran a hose from the engine to the rear tank filler, when im on the front tank, which has no gauge, it fills the rear as well while its running At least I can run the big rear and have an emergency reserve! ( Till the fuel switch ***** completely)
Clb
Another old truck
nannyfornia
My first thought was....
Write a check.
But you win:dunno
Cubey
Van dweller
USA
Why not just bypass the valve and carry a 5 gallon jug of fuel for emergencies?
Oldschool280
Hudson valley
Yes if somebody wasnt aware of the setup, you could run-on the front tank and overfill the rear. The idea is to use the tank with the gauge and have the ability to use the other in an emergency till, i drop everything and repair
Tyler9828
