Here we go, after a few phone calls between Gary and myself, along with PM's and open discussion of these meters in the forum; I got my meter hooked up today and voila it works
Some of you may have followed our talks about meters and others may have passed but Gary and I have been really our heads trying to figure out these meters.
Some background may be in order.
I picked up my meter from ebay and when I got it home it worked and I could read the timing off my truck. I was not happy with my line clamp it looked broken but I was getting a reading.
Just a couple months ago I dusted the meter off and went to time Can30diesels truck and wow...just reads RPM no timing nadda.
Hmm...
bring it home test it same on my truck ***
Talk with Gary he thinks Mag probe cause I get a RPM reading from clamp, he sends me some clamps to test/use and see if this changes things, NADDA but the clamp fits my line supremely better than mine. I'll mic my clamp and see if my hunch plays out that it's for a smaller diameter line later tomorrow when I do some pictures for this thread!
We discuss Impedence of mag probe and whether it has continuity to tip or not...mine had none and I forget whom chimed in but they had 50 Ohms across the 1/8" jack tip to shank, I check and I had about 35 Ohms. We discuss that maybe there is a minute AC blip when the tip sees the slot in the harmonic we discuss plenty...all to be tested.
Now today I took the meter apart removed the main board and started testing the small plugs where the two different connections are made one each for line clamp one for mag probe.
Line clamp 1/8" mono plug seems to be ok, it was sloppy but that was an easy gentle fix for me to get the tip to contact.
The magnetic probe plug is smaller than the 1/8" one so they cannot be mixed up. I go and plug in the mag probe and it all seems good. I take my meter and run some tests for continuity from tip to the wires leading away...
HMMmmmmm....nothing...*** remove the plug test the wire and the contact at the receptacle and all golden...GO and get glasses from house so I can see fine detail...NEW reading glasses make a big difference!
Hmm...it appears that the tip contact has flipped under and when you plug the tip in contact breaks...I change that back so tip makes contact check continuity and I'm golden.
I reassemble the meter, go to truck and connect it all up. Looks good, line clamp from Gary very nice! Mag probe in place go to start and get going...come out read meter -20.0 timing STILLWTF, so shut down recheck everything, low and behold the mag prob was not fully inserted to the stop collar it has on it that I previously set for depth. OK so slip it in all the way and recheck all my connections CHECK! Start truck come out and flick switch on meter...looks to be bout 7.4 degrees or there bouts at as close to 2000 RPM I can get it settled at!
So I'll be TAKING it apart again tomorrow to take some detailed photos for Gary to see what I was dealing with so he can test/check his meters and see whats what. Let us hope we have located a potential issue and is simple to fix. If so and Gary sees what I saw, then he can get his meters running again
Without further Ado...Just a taste of what I saw! A working meter I can now help people locally or when I travel with timing their trucks.
http://youtu.be/7pZK5Pwe22g
Hope this works for Gary
Enjoy
Al
Hmm...
Enjoy
Al
