Yup, gotta use antiseize on the injector thread. Copper based would be my first choice, but even aluminum based antisieze is better than nothing. You might want to use a very small amount between the copper washer and the bottom of the injector to help hold the washer in place during installation. Torque the injectors down to 35 ft/lbs.
Diesel is what I usually use on the oil rings, but I've also heard of guys using petrolium jelly as well with good results. Not too much, just a thin coat.
Be sure to reinstall the injector line clamps if they were removed to during the injector swap. They prevent vibrations from damaging the injector lines. Without them, you will likely have a line or two crack/fail.
Heath
