Chevyboy_0
Mr.SunnyDisposition
So i finally got around to plugging off that water fuel seperator and got her fired off!!! i drove her around for a bit today then let her sit for a few hours and when i came back to get her it took ALOT of cranking to finally get her lit then she died and it took ALOT MORE cranking to get her lit again.... im thinking shes still sucking air somewhere? but i dont know where else to check? i replaced the injectors and return lines a while back and i didnt see any wetness on them? could it still be the fact that there is still a bit of air in it? or is it possible when i fixed the return line from the filter to the #1 injector line it sucked air and it just got run through the motor?
Any suggetions?
Any suggetions?
