f-two-fiddy
the dieselmans page has all the parts numbers listed. I'd stick with OEM on these. The ones on my 85 lasted 20 years without leaking. I believe I paid $18.00 for all of them. IP/filter, lift pump/filter & return line T
hjalbert said:Did those seals from ebay work out for you? thanks
TLBREWER said:Yep. Pretty good deal I think. The hardest part was getting the old hardened seals out of the fittings. I did have to re-tighten the fittings after about 2 weeks. Started getting air in the system somewhere. Tightend up both fittings on that line and no more leaks...now if I could just get the valve covers to stop leaking.
Tom
