IP steel supply line ***
f-two-fiddy
Duluth, Mn.
the dieselmans page has all the parts numbers listed. I'd stick with OEM on these. The ones on my 85 lasted 20 years without leaking. I believe I paid $18.00 for all of them. IP/filter, lift pump/filter & return line T
Ironman03R
Risingsun, OH (NW OH)
If I remember right, the OEM turbo oil supply line uses a similar setup. Mine has been seeping for 4 years now but I have not changed it because the dealer can only get the whole line. I wonder if the fuel line seals will work.
ramon f350
Ft Worth TX
Iron man they are the same seals I will try to get over to the shop and get the part number for you I got mine at the international dealership mine was leaking on the bottom side of the line so hopefully that will cure all of my leaks
Ramon
TLBREWER
Windy B Ranch
Moriarty, New Mexico
I just got this off eBay for $9.99.
“DIPACO PRODUCT”
6.9 / 7.3L PUMP INSTALLATION
APPLICATION:
6.9 / 7.3L Navistar & Ford
THIS KIT INCLUDES:
(2) 5/16" Fuel Line Sleeve
(1) 3/8" Fuel Line Sleeve
(1) Fuel Inlet O-Ring
(3) Pump Mount Bolt
(1) Pump Mount O-Ring
Should be in my mailbox any day now.
Tom
sign_man
Just wanted to add that's why the brake lines have the coils at the master cylinder. I had a copper line run to an oil pressure gauge with a brass ferrule. The line eventually work hardened and snapped off after about 3 years (Chevy 350).
hjalbert
I went by my local pump shop, and they were not sure of what I needed so they gave me several to try, but none of them compressed, I believe they were to short. I can't complain though, they did give them to me. I guess I will order off ebay, allthough I would much rather just replace all of them with barbs to run fuel hose.
TLBREWER
Windy B Ranch
hjalbert said:
Did those seals from ebay work out for you? thanks
Yep. Pretty good deal I think. The hardest part was getting the old hardened seals out of the fittings. I did have to re-tighten the fittings after about 2 weeks. Started getting air in the system somewhere. Tightend up both fittings on that line and no more leaks...now if I could just get the valve covers to stop leaking.
Tom
tractorman86
Buckeye, AZ
Tom
you too huh?! :rotflmao
Loganm223
