ip gone bad
Michael Fowler
Bel Air, MD
The shafts are breaking with the engine at idle while your are bleeding the injector lines?
WOW!
Don't jump to conclusions and pull the engine, unless/ until there is solid reason to do so. Right now that sounds like a shot in the dark. I can't think of anything internal to the engine that would cause the IP shaft to break, so it must be either the IPs or your procedures, ( no insult intended--just trying to isolate the cause...).
fuftransport
williams,ca
so i got one to work. but i think i got it way out of time. just blows out white smoke. do i need to advance timing.
The wrong bolts in the top mounting ears of a water pump can break IP shafts. Just sayin'. :dunno The only other thing I've heard of that will do that is a broken crank.
Gerhard
