dieselman29200
Pa. Oil Burner
I bought a 1987 F250 about a year ago, and in good mechanical shape. I did replace a few parts but nothing major and it runs fantastic for an 87, that being said, I been doing a lot of research on the turbo systems and really liked the hypermax over the other two. I happened to find on craigslist a used Hypermax system. I had to order some parts through hypermax to complete the install, I must say they treated me very well, they replied very quickly and I recieved my parts within three days! The most expensive parts I needed was the exhaust piping, (up and down pipe), everything else was reasonable. I did purchase the down pipe, and managed to fab the up pipes from 90 degree elbows and flexable pipe. Hypermax wants $125 a piece for the up pipes! I am going to run the stock fuel setting for now, as I do want to get the proper gages to go with this turbo in order to adjust the pump.
I dont believe that my heads are leaking, but am wondering if it would be a good idea to retorque the head bolts to 85ftlbs. Would this be a good idea to prevent any gasket issues, or would it be better not to touch them?
The truck has 110000 miles that I know of, it doesnt have the hundred thousand on the odo. I do believe that it is only 110000 because it will start every time (even in the dead of winter) with cycling the plugs only once. I am compairing it to my other idi that had over 200000 on it, (it was very hard to start in the winter). Am I wrong to turbo my idi without doing any major engine work? Any thoughts or suggestions would be great, and thanks for any help.
