Installing a ZF S-47 Any Ideas for the Speedometer??
1Turbo10
Atlanta
I am replacing the old T-19 with a S-47 I am rebuilding. Problem is the ZF has no place for a Speedometer input. I have an 87 2 wd CC Dually and I do not want to loose the speedo!! Any Ideas would be welcome.
1Turbo10
Atlanta
Gps speedo is a thought,anyone make an Electronic one that would use magnets ane read driveshaft rotation??
jaluhn83
Upper Marlboro, MD
The ISSPRO programmable speedos work well off the 10.25 VSS, and IIIRC, they sell a pickup kit to mount on the driveline if you don't have a VSS.
Black dawg
sw mt
why not convert the trans to use a speedo while you have it apart?
I "think" the main shaft is different. Won't have the hole for that little locating ball. At least that's how the 1356's t-cases went. But I "think" all 47's should have it. By the time of the 52's, all trucks would be the vss driven in the rear end. Don't quote me though. Been awhile.
1Turbo10
Atlanta
Yes,main shaft and case will not allow a speedo Gear. I will check out the Ispro set up,Thanks.
Shadetreemechanic
Monteagle, TN
You could use an s-42 case. Isn't the only advantage to the s-47 the lower first gear, or are there other upgrades worth having in an s-47?
Lance
