Mojave Red said:
I installed a 38 gallon aftermarket just over a year ago. The tank came with a kit that consisted of some extra long bolts and a copper tube to be used to extent the pick-up tube. Both my senders where shot at the time so I bought new ones from Ford. I use a tube cutter to cut the rear tank pick-up tube at the center point, inserted the coper tube and soldered it up. I extended the float using a heavy duty coat hanger. To date - no problems. If I where using a Bronco tank, I would use a Bronco pick up. I can tell you, all the metal part on the new Ford "Diesel" pick-up are galvanized. I went to great lengths to make sure my new tank would be diesel compatible but have never seen any "real" proof or explanation why a diesel/galvanized combination is bad.
You're going to love the extended range the large tank gives you. Just be sure to have adequate health insurance to pay for the multiple heart attacks at the pump.
It's alway ok to PM me... Brian
Here is what I have in my "Library" about the "galvanized" tanks. OkieGringo
Why NOT to use Galvanized Fuel Tanks in a Diesel Engine
Original post by Member John348
The material the in "good" tanks are made from is ni-terne or terne strip.
Ni-terne is cold rolled, flashed with nickel then hot dipped with
90% lead 10% tin give or take a couple %pts.
NO Zinc.
Terne steel is hot dipped with just lead and tin no nickel flash.
Galvanize is hot dip zinc.
Galvalume is hot dipped zinc and aluminum.
Galvanneal is dipped zinc then strip annealed.
My steel mill expertise for you.
Diesel fuel coming in contact with zinc, copper or alloys containing them will cause accelerated aging of diesel fuel.
These metals will quickly react with diesel fuel to form unstable compounds.
In Other words, don't use zinc coated tanks use lead & tin
