Its true replacing them as a unit is the best bang for your buck BUT at 16 I couldn't have spent 700 for a brand new fuel system unless the parents wanted to help. You need to find out which pump the shop replaced since there's a low pressure lift pump and a high pressure IP we've been talking about. Also peek at your injectors if they still have that IH grey they are original and probably need replacement. If not you might still want to pull them and have them pop tested and see how they're doing. Make sure its a shop that will let you watch or known to you and your family to be of good integrity. Crapheads might try to rip you off since you're young and they think you don't know anything. If they're bad you can get a set of remans from ebay pretty cheap. Not a bad deal, and not a lot of complaints. The IPs are best handled by a competent local shop, for ease of warranty issues and more personal service/less downtime, that is unless you want a Moose or DPS unit, if you go that route, Mel has a much better reputation than DPS, but you really don't need a "hot" pump like that until you get a turbo and trust your headgaskets. Are you even sure anything is broke? If not save your pennies, these trucks are great but they will nickle and dime you to death. Take care of it and you'll have a great truck to last you through highschool and longer if you wish.
