The FNG
NOT a Powerstroke!
I'm researching a solution to this right now and I should have something posted soon. I assume you are running a 1-tank system and/or starting on WMO. The simple answer is you are beginning to form coke on your injectors because oil will not completely combust when the engine is cold. I would pull them and clean them. Then I would work on a 2-tank system and start and stop on diesel. Just my opinion... Or you could drop your pile 'o' problems on someone else and get a FORD! (had to do it)
My solution to clean the engine is to run it hard up some hills for a tank with d2 and an ass-load of diesel kleen. Take it out of OD and run the rpm up and bet some boost goin....then give it a proper cool down time when you shut it down.
