idijack
anybody figure out why my good running injection pump quit pumping while I was changing the engine.it is getting fuel to the pump and the solenoid is working. it is a 90 engine put in a 89.
the lines r loose foot feed wide open, getting fuel from tank,timing not moved, no fuel getting pumped by injector pump. the front of the pump is turning.
But certain types of waste oils or bio will eat up the internals, IIRC.Another failed solenoid.. Where are you getting these solenoids or what are you doing that might cause them to fail. Mel told me once these solenoids can be cracked and still work fine.
