Alex S
Jeoff
titel says it all
If a 7.3 and 6.9 sounds the same why does a GM 6.2 and 6.5 sound way different
anyone notice that
anyone notice that
+1If you mean between a 6.2 and an electronic 6.5, the electronic engines always sound crisper/sharper due to different injection pressures and timing. Listen to a mechanical cummins vs a 24 valve electronic engine, WAY different. We used to have some mechanical n/a 6.5s at work, and you couldn't tell it wasn't a 6.2.
Travis..
The 6.2 and 6.5 are entirely different horses, like comparing a Detroit to a Cummins; whereas,
hmmmm ok thanks,
its there any advantage to that electronic crap on the GM pump
The 6.2 and 6.5 are entirely different horses, the 7.3 is just a different version of the 6.9, with many interchangable parts.
Block to block the 6.2 is almost identical to the 6.5 depending on the year. Unlike the 6.9 and 7.3 GM changed little things year after year to "improve" their design but overall the 6.2 and 6.5 are very similar.
unless you have owned a GM, you have very little ground to criticize them.if the wanted to improve it they would put a 6.9 or 7.3idi in it
I can say that I dont ever want to work on an 83 6.2L powered camper converted van ever again.
