IDI parts
Double-S-Diesel
parts seller
derry pa
just a partial list.
c-6 2wd trannys, 1 rebuilt, 1 used, $100 obo each
86 dually rear under a box van not sure of gears , $200
86 dually rotors, spindles etc also on said box van.include, calipers etc $100
86 6.9 short block, no heads, heads were cracked, original engine from van $200
set of heads from a 84 6.9, cleaned and magged, 2 small valve seat cracks, $100 for the pair.
one set 7.3 heads came from the 92 truck when the rod broke complete and assembled, $300 pr will refund money if they are checked and found to be bad.
oil cooler from 94 idi $50
dana 70 355 ls $200
1356 transfer case from the 88 tk $150
88 reg cab no rust has some accesory holes, $50
tons of small parts, if ya need just ask, gotta make room, and dont need all these parts.
Nick
metrojd
Pittsburgh,Pa
dulley rear
Nick,
The rear out of the box van , Do you know if that would wouk under a single wheel pick up to make it a dulley?
Let me know
Thanks
John
subway
be nice to the admin :D
York PA
what are the d70's out of? i want a locker but i think my truck has the stearling??
Double-S-Diesel
parts seller
derry pa
there out of a 83 and 84, will work in place of the sterling but would loose abs and speed sensor
EZ no tail lights other than the ones on my truck.
john
will get the measure ments on it
Nick
Diesel JD
Gainesville, FL
Hey Nick, how much do you think the shipping would be on one of those 6.9 blocks to Florida? Do you still have them?
Diesel JD
Gainesville, FL
I thought the block was more like 800-900lbs? I've heard of people getting blocks shipped pretty cheap. I would need it for my friend's truck that I have listed here. We're seeing what he can get for it as is, if no takers, we'll try and swap ina runner to get what its really worth. I will see what I can find out from freightquote and others. Thanks,
J.D.
hjalbert
any chance you have a set of injector hard lines? All I really need is the one going to the Injector closest to the front of the block, passenger side. (not sure of the cylinder number) Thanks
metrojd
Pittsburgh,Pa
Dana 70 Locker
Nick,
Let me know if it is a dually or not.
Also get me the #s on the tag so I can see if it will work for me or not.
You got my# call me so i can make a move.
Thanks
John
metrojd
Pittsburgh,Pa
Nick are you still there?????
Nick,
get back to me on what you want to do!
Do you want to sell the rear or not????:confused:
If not let me know so I can move on.
Thanks
John
Russ
Idont do injectors
New Brighton PA
metrojd, Nicks been very busy lately starting a new shop. I'll give him a call and tell him to call you.
4x4TruckinGirl
"Cowgirl"
Dixon, MO
diesel JD..... as far as shipping is concerned, i know a few people who have trucking companies that are based out of Ocala, FL and frequently run up that area in the north... they haul cars, but im sure would pick that up. Let me know what kinda quote you get or if yea want me to see what my friends will charge. ;Sweet
BrannonB
