janos1
That's gonna hurt
I have been having a growing problem with getting my motor lit once it has sat for a while. Overnight and in the parking lot at work. I am beginning to believe that the lift pump is the culprit. The motor worked fine in the donor truck, barely turning over before it fired. I think the valving in the pump is leaking down and allowing the fuel to return to the level of the tank. Drawing air in thru the return line. I would like to get some input on this.
