I need a set of DRW front 4x4 hubs ASAP!!!!!!!!!!
Columbus, Georgia
My wife is stuck out of state and is dealing with a failed hub in Tennessee and I am in Iraq and cannot help. She needs a new or good used hub for a D50 TTB front end. A dually hub from a 60 will work just fine. From what I have found out they are the same.
Please let me know if any of you have a set collecting dust that you want to sell.
first, D50's never was a factory dually option.
you will need to move your dually adapter over.
second, you have broken the spindle from what I can tell in the pic.
I do have a complete front axle that I am willing to part out.
it is off a '92 f250 4x4 SRW.
lmk
calc ship at 50lbs(worst case) from 95050
read up on this post....
http://www.oilburners.net/forums/showthread.php?t=15675
here's a couple of pics of what you're up against....
they are only a visual example not the real d50/60 item.
subway
be nice to the admin :D
York PA
i got an extra D50 set up to if needed, like mentioned looks like you will be getting a whole other lockout hub, spindle and bearings at least. looks like no body got hurt though.
do you know what all will be needed. i could send a set up from the knuckles out.
actaully lookes like the front of the axle is just a shell without the center section bolted on.
edit - my set up is from a 94 4x4 diesel SRW also, no dually adapter....here
http://www.oilburners.net/forums/showthread.php?t=23773
Columbus, Georgia
Okay, let me see if I can address everything.
Upfront, that is a true factory one ton dually TTB D50 front end. 85 is the only year I know of where Ford did that. That is why I used an 85 TTB dually front end it is the only one I could find. From what the mechanic said the spindle if fine and believe it or not the bearings even survived. Of course I am not taking a chance with them, they will be replaced. The problem is a spindle nut failure. They came off and the hub did not come apart right away. The inside bearing slipped out of position and that is what ate up the hub.
A new set of Stage 8 spindle nuts are on the way so that should eliminate any spindle nut failures in the future.
To clear up the confusion, yes it is a four wheel drive conversion. I used the TTB (out of an 85 F350 dually) because I like those front ends. I was home on leave when I did the conversion and ran out of time. That is why the differential and axles were not installed.
That is a ten lug bolt on conversion. The TTB D50 shares most of the same hub components as the D60 so I doubt the rim and tire combination is to blame. I have never had a TTB front end fail on me before, even when I had a set of super singles.
Ford said they cannot get a hub any time soon if at all. But, they at least list it
She is located in the Tri-city area of Greeneville in east Tennessee.
I’ll try and get some photographs to post so you all can see the hub itself.
I do not mean to throw out a sob story, but my wife is there because my grandfather is not long for this world. And I may end up going home on emergency leave. So I cannot stress how important it is we find at least one hub soon.
Columbus, Georgia
Towcat, thanks for the offer. Worse case scenario just the get the truck running again I may have to take you up on it and borrow a set of stock rims and tires.
Columbus, Georgia
Car-part has some listed, my wife is going to call them.
One place near her claims they can get the hub. But she siad they sounded unsure if it is the correct one or not.
Timthetoolman
Dayton, Tn.
Don't have any parts but if I can help I am a couple of hours away from Greenville.
I do have a 1990 dually donor truck for parts. :dunno
m2rtin
