condor74
ok well the story starts when I aquired this 1990 F250 7.3 IDI 4x4 pick up last winter. I drove it about 50 miles to my house in the middle of a rain storm. The truck had been sitting about 2 years because of expired tags. It is supposed to have had the trans rebuilt shortly before it was parked. There is receipts in the glove box confirming this. I parked it at my house since last year and just now finally got the title situation and tags paid up on it. I drove it today and when it was cold started in the morning it ran and shifted good. It had a delay going in to reverse but I have heard a lot of these do that. After I got to work and the truck was at operating temperature I tried to put it in to reverse and it didnt engage solidly. I was able to back up giving it throttle but it was higher rpm than is normal. I I let it cool off and at lunch time I started it up and reverse was working again. I drove it to my house and reverse was slipping again when I got home. I then drove the truck around to see if all the other gears worked. The did but as I drove it and tested it I started to slip at highway speeds. Usually at 55 miles and hour I am under 2000 rpm. It was slipping up to almost 3 unless i completely back out of the throttle and very lightly held the throttle it would stay at 1900. I turned the over drive off and it caused the rpms to climb instantly and they came back down when I turned it on again. I then drove it strait home and parked it. Lower gears seemed to hold still going through the neighborhood. I let it cool down and drove it agian in the evening. All my gears were back again. It was 104 outside today and was in the 50s when I brought it home last winter..
No flashing od lights Tach doesnt jump or anything. All my brake lights work.
There only about 4000 miles on the overhaul but there is no warrentee as I was not the owner of the truck when it happened it was done back in 2008.
I havent serviced it and the fluid still looks red.
I am hoping I dont have to take the trans out and have it rebuilt again.
Things I am thinking is maybe a loose or leaking valve body, wrong fluid, burnt up transmission.
Any ideas?????
Any ideas?????
