LUCKY_LARUE60
I bought this truck 3 weeks ago and it ran a little rough, had codes run twice and could not find the problem.
Well had the CPS replaced by Ford under the recall and they ran the codes again and they said no codes came up HHHHHHHHmmmmmmmmm. Motor sill running rough, ran across a friend that has worked on a lot of Powerstrokes and we took my truck to his shop and he scaned it again and #8 code came up so he did a buzz test and he got 7 to buzz. He didn't have time to tear in to it so I broght it home and took the vave cover off and started messing around. Started the truck and stared unpluging the injectors one at a time and when I fot to #6 nothing changed when I unpluged it. Called another friend and he brought me 5 injectors and I changed out the injector. Man what a difference that made, it is running on all 8 now and so smooth and a ton of power.
All I can say is WOWWWWWWWWWWWWWWW
