I have been running the hydroboost brakes on my 79 chevy c-30 for about 25 years but these on my Ford are way better. I'm really not sure why. I had to bleed the brakes alone. The fronts worked fine but the rears wouldn't bleed down. So I tried to move the truck with only the fronts up and working.... Kinda scarry. So I tried pumping the brakes and bleeding the air out of the line to the rabs valve. It started to work so I pumped up the peddle, applied a LARGE concrete block on the peddle and got under and finished bleeding out all the air that was in there. I will take it to a shop or get some help to flush out the complete system to insure all the air ir gone. Heres the deal... The brake peddle is so far up when it engages the brakes its scarry. I'll bet the peddle does not move 1 inch and I'm feeling things stopping quickly. I feel this is due to the hydroboost, the 1 5/16th inch master cylinder pumping fluid into a system that was designed to operate on a much smaller master cylinder. Also I have the F450 brake peddle that has more leverage because the pin is closer to the pivot point by about 1 inch. I know this really is way better than the vacuum assist brakes I had. No, I did not adjust any brakes either front or rears to get the slop out of the system so it not like I brought the rears up so close to the drums that there dragging. The foot pressure is really a lot less than the vacuum assist brakes too. Overall I would reccommend this changeout to anyone thats interested.....
