jaluhn83
Going to combine several things here into one thread:
1) Is the hydroboost a bolt in conversion for an 85 F-250? I've seen some info saying the brake petal pin had to be modified and some that seems to indicate it's a bolt in fit.
2) Any recommendations on a ceramic coating shop in the socal area? I'm going to get the piston tops coated but don't really know what I'm looking for as far as picking out a shop / coating type. Would it make sense to coat the valve heads / chambers / anything else while I'm at it?
3) What are ya'll's thoughts on aftermarket air filters? The setup I'm running now uses a K&N cone filter that I picked primarily because it was what I could find that fit the available space when I was putting together my setup. I have since seen a lot of negative info on K&N filters so I'm considering going back to a conventional filter, though I don't know what I'd use. The nice thing about the K&N is I can get pretty much any size easily. The cummins guys seem to like a big cylindrical paper filter about 10"x10" but I can't think of how to fit that on my rig. Any ideas?
I was looking at the space outboard of the brake master cyl but it's not big enough and getting the piping around the master cyl would be challenging.
