First I just want to thank you guys for helping me with the information about getting my truck running again. Really helps to know those torque numbers and proper procedure. Anyways, it only turned out that one glow plug came out with out the tip so I didn't pull the other head... However, I've got it running again but now there is this mysterious humm that is strongest when my head is over the ip. I didn't do any thing to pump just pulled it, set it aside and then put it back in. Is this a tell tell sign that the pump is about the quit?
Note that the humm is a lower pitched humm at low rpms and then increases in pitch with rpm especially when I put my foot into it while the rpms haven't really had time to change much (like under load). Any ideas? Did I possibly get a leak in the intake some where? Having seen what the "valley pan" gasket is I think I could see where it would be real easy to screw it up... What would be a good way to test for an intake leak? We used to spray brake cleaner around the intake of the small block chevys and listen to a change in idle to indicate a leak...
