How to use a PSD Downpipe on your IDI factory turbo
Status
Not open for further replies.
Mr.Diesel
Goshen IN
OK...so what originally brought me here was the search for a DP for my first ever, new to me 94 Turbo IDI. I was directed here from another site. After a lot of lurking around, and asking some questions about other members set ups I decided to tackel this job myself, and here is how it played out:
I bought a 4", aluminized OBS Powerstroke full turbo back, "off road" (no CAT) exhaust, with a muffler off of Ebay from seller the_power_shop. It set me back a little under $300 with the shipping. The exhaust will work for all cab/bed configurations, and bolt up from the DP back went off with out a hitch.
The following is how I modded the DP that came with it to work with my Factory Turbo. Here are the two DPs next to each other. Note the bend at the top of the OBS unit:
Mr.Diesel
Goshen IN
I then cut the ends off of both DPs. On your factory one, you want to cut about 1/2" BEHIND the factory weld:
Mr.Diesel
Goshen IN
I then ground the little "flanges" off of the factory piece. I used a heavy hammer to tap around the OBS unit untill I had a slight taper built into the very end of it. Hard to see but that is what the last pic. is of:
Mr.Diesel
Goshen IN
All welded up...
Mr.Diesel
Goshen IN
This is what I ended up with:
Mr.Diesel
Goshen IN
Once I had it all bolted in, I discovered on my truck the alignment to the CAT Delete pipe was not favorable. I decided to fix it by adjusting the angle at the end rather than at the top. I had the best clearance to the fire wall that I thought I could get, so this seemed like the best option for me. The OBS unit is 2-piece so it goes in/out VERY easily, and I was able to leave the top piece bolted to the trubo...
Mr.Diesel
Goshen IN
That's it. The rest is the same for either an IDI or a PSD, very straight forward. A sawzall, a welder and half a day and you're all set! I sugest having a friend around when it's time to bolt the new DP to the turbo, as it is VERY hard to hold it up in there and get the V Band clamp around it and tightened. Hope this helps some one, enjoy!
david85
Campbell River, B.C.
This is a topic that comes up once in a while because getting IDI downpipes can be difficult. I think a lot of guys suspected this was a possible solution, but so far you are the first one to document it.
Thanks for sharing;Sweet
Rot Box
Northern Utah
Lewiston
Very useful thanks for sharing! ;Sweet
Although it is a completely different setup I have been contemplating something similar with my 088 ATS turbo...
6 Nebraska IDIs
WOW Awesome job man! I think people have talked about doing this before but no one has ever actually done it and taken pictures of it the way you have. Thanks!
argve
Resident Fruitcake
Gwynneville, Indiana
Good Job! hat's off to ya...
You know now that you have posted this you will have to start making them for folks on here.... So hopefully you saved all patterns...
sootman73
Wauseon, OH
thats 4in? looks like three to me.... how did you fit 4in in between the trans and firewall? i could barely fit 3" in there.....
Mr.Diesel
Goshen IN
Sorry 4" exhaust kit...3" DP. That's the way all kits are I guess I just figured that was a given...
sootman73
Wauseon, OH
oh okay. i was confused because you said 4" turbo back which they sell. they actually sell kits all the way up to 6" right off the turbo.
but yea that looks good. thats about what i did to my truck but with 3" flex cause no one would bend me a solid pipe.
Status
lewisstevey7
