SparkandFire
We're drinking beer
One look at this picture should enlighten as to why this job sucked...
Drum was fused onto the hub so only way to do a brake job was to remove it. Reason for this was neglect - the brakes had been run until the rivets cut very deep groves in the drum, and the adjuster was seized up so I couldn't back the shoes off far enough to clear the rivets. Had this been a semi-float I would've been in there with the cutting torch.
Word to the wise - Replace/recondition EVERY component in that drum or you will be back for more. I was. I cleaned up the adjuster, anti-siezed it, replaced springs and hardware, the drum, shoes, wheel seal... BUT I cheaped out and didn't drop $12 on a wheel cylinder and as such, yes sir- back for more. Noticed the other day the cylinder was leaking brake fluid through the rear bore.
