How NOT to do a rear brake job on a truck
SparkandFire
We're drinking beer
Aptos, CA
One look at this picture should enlighten as to why this job sucked...
Drum was fused onto the hub so only way to do a brake job was to remove it. Reason for this was neglect - the brakes had been run until the rivets cut very deep groves in the drum, and the adjuster was seized up so I couldn't back the shoes off far enough to clear the rivets. Had this been a semi-float I would've been in there with the cutting torch. cookoo
Word to the wise - Replace/recondition EVERY component in that drum or you will be back for more. I was. I cleaned up the adjuster, anti-siezed it, replaced springs and hardware, the drum, shoes, wheel seal... BUT I cheaped out and didn't drop $12 on a wheel cylinder and as such, yes sir- back for more. Noticed the other day the cylinder was leaking brake fluid through the rear bore.
What a great pic of that horrible coil spring that holds the shoe to the backing plate. Thats where the special release tool is really a "go to bed with tool" that you need LONG BEFORE this job is started. Been there. done that with one good hand too. Never will do that again either...
HammerDown
Glenolden Pa
Since 1988 and 'new', I've only replaced my rear brakes maybe 3 times.
Special tool...?
Yes.. That tool that is required to remove that coil spring seen in this pic. Snapon makes one as do many other tool companies. Towcat suggests a tool made by the matco truck guys. Says it wont break like the Snapon tool does.
I wouldn't say it's required, but could be easier.
I just use my old school brake spring pliers.
Sent from my USCC-C6721 using Tapatalk
Wyreth
Certifiable Noob
Las Vegas, Nv
Gary, perhaps you could post a picture of this amazing tool?
I never liked any of the lame brake spring tools I've seen, so I've been making due with my giant needlenose pliers for over a decade now, and they usually work rather well for me. However, if there really is an easier way....
1466IH
waterloo, il
does anyone have a part# for this tool i have never seen anything special for these hpld downs besides the old fasioned pliars
yARIC008
Drives really slow
Orlando, FL
Special tool...?
Probably means your brakes are never adjusted correctly. They wear down just a little bit then don't do anything. Have to keep adjusting them to have good brakes.
I never use any special tools for drum brakes. I just use some needle nose. Have to turn into the Hulk to do it, but that just makes it more fun.
DaytonaBill
Try making this...
chris142
SoCal
I have had a matco one that looks like a 2 pronged fork for atleast 20 yrs.makes that spring easy.
I saw those on amazon for $10.
Looks like it would definitely make things easier.
Edit: Actually Matco sells them for $9.95.
A trick I've used is to grind off the head on the "nail" that holds the spring in place on the backing plate. That will give the shoes a lot of play and you might be able to dislodge the drum. +1 on the old school brake pliers.
Iowa 73
FNM
IA
Yep, just use a drill and drill the heads off the retainer pin. This relaxes the springs.
I use channel locks when working on the brakes on these trucks.
