racer30
I think the IDI is plenty strong enuff to spin up to 5000RPM It is more about what kind off power and torq you can get at that rpm?.. Is it realy needed to turn that fast?... IMO turning up past 4400RPM would not be needed. In my simulations on the computer the engine is pulling to 3800 pretty hard But starts falling off past 4000... And to do that I needed to play with the cam specs to get it to run that fast. There are so many things to think about. you can build a low rpm engine or a high rpm engine It just needs different cam specs. and turbo size to make boost in the range you are looking for. I have built engines that run on methanal with 14.5 to 1 comp that made 515 hp on a dyno and they had way smaller rods and pins inside them almost scary light pistons infact the only engine failure I had was from a Kieth Black piston breaking at the oil ring grove. I will say when I took apart my first IDI and found all the pistons were cracked, one was grenaded and you could tell the engine had ran on 7 cylinders long enuff to grove the cylinder with the rist pin 1/4 inch deep. I knew this engine was hell for stout. Just need to make sure I dont over heat the pistons in my engine and I think I will be ok.
