85_IDI_4x4
about those valve springs not working above 14,000rpm.
I was trying to find how to calculate how much force is being exerted on a piston while the engine is running and came across an article from car & driver where the guy was discussing how F1 cars can make 800hp out of 3l and spin 18,000rpm. Turns out Renaults solution to the problem was to eliminate the valve springs all together and instead replace them with mini gas charged piston-and cylinder assemblys.
P.S. Im still trying to find the formulas to determine the forces trying to yank on the pistons, probably learned it in HS physics but have since forgotten. Anyone know how? With a little math one could theroritically find out what rpm the connecting rod bolts would fail or permantly stretch
P.P.S. The article is called "yanking the crank at 18000 rpm" its from a '99 car & driver mag
