basilbowman
Thanks everybody - it is the tach sensor, I just did a **** poor job of describing it (cylinder three inches long? What's that?). Anyways, I'm headed over to Shadetreemechanic's tonight after work, he's graciously offered to help me out.
As far as going veggie oil goes, it seems like the thing to do, I mean, the rest of the truck is solid, it's just this detail. I'm careful, and I feel like I've got a pretty good setup. I've got SVO in the front tank, with an in tank heater, running HIH up to where I've moved the pollak underneath the hood. I've got an aftermarket heated filter that I've yet to splice onto the grease line, but I've got a filament wrapped around the steel line coming off the stock filter into the injector pump that I've wired up to switch on when I flip to the SVO tank. I always purge and start up on diesel and wait until the heater is good and hot before flipping over and I don't really run straight veggie oil, I toss a gallon or two of diesel in every tank of grease.
From what Shadetreemechanic has told me, and from the info I'm getting from you guys, I don't think it's going into limp mode - it's not redlining as I go down the freeway (I'd not have put quite so many miles on it if it were) and I can hear it shift all the way up and back down. I can flip the O/D off and on, and it shifts just like you'd expect it to, and the light works, so it's not flashing like Shadetreemechanic asked (already expecting the answer, I think). It feels like it's shifting early, so I'm going to play with the TPS settings tonight, and it _is_ shifting hard when it does shift, but I can kind of goose it and let it relax into that shift to ease up on it, which I've been doing.
I'm not really sure what's up, but I'm going to let the pro direct from the lawn chair while I spin wrenches tonight and I'll report back in the morning, hopefully. In the meantime, time to edit my signature and get to work. Thanks for the help, everybody, I'll be back shortly,
-N
-N
