HIghest WMO/Diesel Ratio on a stock 6.9l IDI?
oregon101
salem oregon
I've got a 89 7.3 that I'm running 100% WMO once it is warmed up. If I only shut down for 2-3 hours I fire back up on the waste oil. So far I'm having no issues.
Devilish
Nv
I'll let you know after next week. I bought a mercedes 300 sd in Las Vegas so I'm gonna take my 87 turbo dually on the trip and am gonna try and run 100%.
But first I'll check the injectors to make sure they're up to *****.
mankypro
Learning Slowly...
Boulder County, Colorado
I have all the parts for my filtration rig, I plan on taking running my front tank (16 gallons) dry and using it to test blends with the rear full of straight diesel. Once I'm done testing I'll switch since the rear is the larger tank (45 gallons). I'll start 50/50.
subway
be nice to the admin :D
York PA
i run 100 in my 7.3, same injection system, i do run it through a plate exchanger to heat it and start and shut down on a lighter mix.
power seems about the same maybe slyightly less and EGT's seem to go down about 100deg.
The biggest issue for most is getting them to start on 100%. May not be a problem in the summer, but in the Winter, it ain't happenin'. LOL
forcefed
Newark, OH
I can't start mine on 100% wmo now when its warm outside now so I can imagine what it is like when it gets colder. It will start I guess but it takes alot of cranks. Will plugging the block heater in over night help with this issue of wmo starting during summertime??
69dieselfreak
well that nice
rimrock arizona
i live about 100 miles from hell and it gets 100 plus degrees here and its pretty hot during the nite and ive tried to start my trk on 100% wmo and it dont want to start at all it fires eventually but i got one tank good ol #2 and my front 100 wmo when it gets to temp i just switch tanks if i have to let the truck sit for more than 8 hours i shut down on diesel
Ford428CJ
FE Freak!
Klamath Falls, Oregon
I run a 50/50 mix as we speak! But I live in Hi Desert country and It can get real cold at night and hot during the day! I guess it would depend a lot on your area conditions. JMHO
nightrunner84
Dayton, Ohio
Thats what I do, for the last 4K. I pulled all of the injectors about 2 weeks ago and all the holes were clean. Just a little ash on the tips....
mankypro
Learning Slowly...
I basically just wanted to know how 100% behaved combustion wise. The temp stuff I'll worry about. I'm going to run 50/50 first, and then try 100% in my rear tank see how that goes. If the truck behaves then I'll plmub the tank with a heating element of some sort.
sassyrel
iowa
100%--just make sure that about three miles from home you switch over to diesel---will pass thru the lines quick--so your starting on that in the morning--
jrou111
Mobile, AL
I run 90/10 all the time. It takes two GP cycles to start in the morning, but if I plug in the block heater for 15-30min it'll fire right up. I have to run alot of errands, so I stop and start alot. Once the engine has warmed up in the morning, it starts no more difficult than on diesel.
But I live on the gulf coast, so it'll stay 80+ through December.
thamojster
