High pressure fuel pumps
Ruffnek7tree
Northwest
I'm an idiot, I read it as a 24 volt pump, not 24 valve and had to do a critical rethink.
For the 24v it is a constant run pump for the vp44 systems, i wonder how itll perform long term and under varying power mods.
Ill definitely do an update later on, I have a factory turbo setup on the shelf that will eventually make it on my truci, as well as a 90cc moose pump..
I have one of these inline before the pump and filters, and I highly recommend it, only downside is i haven't found one in 3/8, it's 5/16.. but I tighten them to where it doesn't leak.. it's a 50 micron filter that does a great job of keeping the big chunks out of the pump and filters.. my setup is a little different, I have 2 spin on filters instead of the factory one
This one is napa 3972 or wix 33972
nelstomlinson
Delta Junction AK
I looked on their site, couldn't find specs for that 1840 grind cam.
I looked at the Russ Repair website, it's still up. Is the family going to keep the business going?
From what I've read is some things yes. Things like injectors and cam cuts no.
