HHO Bi-fuel
rustygold
conway Arkansas
Has anyone used a Bi-fuel using the HHO generator (hydrogen on demand).
I'm thinking of doing it to my truck not really looking to save fuel just use 100% of the fuel injected in the cylinder.
Been looking they have kits for the simi trucks they said it lowers EGT up to 23% and gave a 30% power increase with a 6% fuel saving on diesel.
Just looking for information might do the kit on mine. If I do it I'll get spec and all that too yall.
Sent from my SAMSUNG-SM-G870A using Tapatalk
No, just no.
Way better means of increasing efficiency.
Matter of fact, search here. You'll find it being discussed many times.
rustygold
conway Arkansas
I know water methanol is a common one, or turbo is a way to lower egt but don't know any other ones out there?
Water. Methanol will not lower EGT'S.
You can play with the mix to get it where you like it.
Turbo + intercooler.
If you aren't seen smoke, you're burning nearly all the fuel being injected.
rustygold
conway Arkansas
Only a slight puff of black smoke under hard acceleration
CDX825
filtration nut
Litchfield,Ohio
There was someone on here awhile back I thought that was playing with HHO. Seem to recall it making a noticeable difference in power.
Also running water/methanol injection does lower EGTs. That's one of the main points in running it, Lower EGTs and more power.
Correct. Water will lower it, but too much methanol will raise it.
Look at methanol as adding a fuel.
A good mix is washer fluid. Pretty good balance.
I've never seen any factual data with hho.
