smokey_and_freya
My 1994 F-350 4WD turbo IDI is leaking a lot of oil from the front oil cooler seal. I've purchased the o-rings but for the life of me I can't get the darn thing out! I've read up on all of the postings about removing the cooler from below the truck. I've removed the 4 bolts from the rear header (1 shorter bolt, 2 medium length bolts, and 1 long bolt) and I can see a gap between the header/gasket/engine block. I can put a 2x4 against the engine mount and pry the rear header with a crow bar but there is no movement. Are there possibly pins in there? Or something else preventing the rear header from sliding off the oil cooler? Should it slide off gradually or will it "pop" off? Another thing that shouldn't affect anything, but the oil filter is still on the rear header (I crushed it with my POS filter wrench).
Any hints/suggestions?
Thanks!
Thanks!
