On my new 1991 7.3idi i am missing the oil filter housing/cooler. Is this the same cooler/ housing on the 1995-2000? or is it a different one? Anything helps!!!!
Supposedly different. Never seen the mounting sides side by side to compare though.
I know the 94+ on the powerstroke has the block heater addition.
I believe they are different, although some use the center section of the oil cooler from a 7.3 PSD on there idi's. But I am fairly certain that the ends are different. Someone here will correct me if I am wrong
Ends & bundle are different. PSD bundle is longer. Only thing in common is 1995 oil filter can be used on both PSD & IDI.
Can use '94 IDIT bundle which has better oil cooling on previous IDIs but not PSD on IDI.
