MIDNIGHT RIDER
- Joined
- Sep 29, 2005
- Posts
- 4,702
- Reaction score
- 142
This information may only be good for the 1980-1986 trucks.
Ever since I did the big-wire/relay modification to my headlights, I have been shooting those twenty-dollar Silver-Stars about every sixty days; I figure due to the full voltage they are now getting, as opposed to the wimpy nine or so volts that they were previously getting.
The bottom two retainer screws can easily be accessed, but the top two have always required me to remove that big chrome/plastic "bezel" trim thingie to be able to remove/install them; this is not the best situation, especially in the dark or in the rain.
I have remedied that situation and can now easily replace a headlight while leaving the bezel/trim un-molested.
I marked the location of the top retainer screws on the bezel, then I cut two notches, about a half-inch high by half-inch wide, that coincide with the retainer screws.
The plastic bezel was easily cut with a plain old wood-working coping saw.
I blacked the sawn edges with a "magic marker".
The notches are not easily seen at all, and not even noticable if you don't know they are there.
Now, replacing a headlight takes two minutes instead of thirty.
