Not really. What you have to remember is that even though these are not "stretch" bolts in the normal sense of the word, they do still stretch slightly as they are torqued. They have to.
The head gasket and head do not stay completely rigid to the engine block, but instead dance around slightly as the engine runs and vibrates. that means the bolts have to have loads of clamping force, but they also have to be flexible to stand the test of time. If it wasn't for this flexibility, the threads would either shear out of the block, or the bolts would break. This is why you don't want to use aircraft grade fasteners that can't stretch when you torque them down because their yeild strength is so high. The bolt will hold too rigidly and something else will have to yield instead.
By increasing the torque on the ARP bolt, you are going past the optimal loading/flex of the bolt even though you may technically still be within the safe limit of the bolt (all that means is it won't break when you torque it down). Also since the threads might not be at the ideal seating in the block of the engine, the stud may settle after the engine is run for a little while and loose some of the clamping load. Retorquing later on may be needed, but by then the nuts will have more friction in the threads after having sat for a while and this is still not ideal.
You can get away with not following these all exactly to the letter, but understand that every corner you cut will come at a cost. If you want to get every dollars worth out of your studs set, then its good to understand the whole story behind the head bolts. And what a story it is.....
