Fordfarmer123
So last year I pulled my motor to do a oil pan I accidentally loosened 4 head bolts realizing what I did I tighten them back down to the torqe setting. I also did my oil cooler o rings. I put the motor back in the truck and after running it for a while I got coolant in my oil. No oil in my radiator. I was wondering if this is a cavitation issue head gasket or oil cooler. I did test each cylinder for compression and they all had great compression! Can you have cavitation and good compression? I’m in the process of pulling this motor again anything I should replace or inspect while it’s out ? Thanks
