Hard starting & Uhaul IP's
Brad S.
NW IA
A while back OldBull started a thread about Uhaul IP's and problems some had with heat soak.
Does anyone know or experienced a Uhaul IP with leak down problems??
My current IP (Uhaul) is not leaking from the bottom weep hole. Injectors are less than 2 months old. No visible fuel leaks from leak off tees or new rubber lines.
I think my problem is a air leak somewhere.
If I put my old IP back on and the problem gets better thats a indicator the Uhaul IP has something wrong??? Right or am I missing something, besides a would be air leak.
Thanks guys.
