vmax3_2001
Ever since I've owned my truck there has been a problem with my breakes. Here's the deal. When I step on the breakes they are very hard then they gradualy soften. You can hear a pressure like sound almost like air brakes when i apply but I don't think they need to be bled, but once and a While they will go almost to the floor. I checked the vac with the thumb over tube method by the master cylinder and the vac seems strong, (I don't have a gauge). Could my M/C be going out, or vac pump? I was also told there is a rubber seal inside by the break pedal that could be bad as well. Any ideas on what or how to check. I'ts probaly something simple, thanks
