JD, good luck on the turbo rebuild. Mine has lots & lots of miles & still tight last time I ck'ed.
orings on pedistal yeah, I forgot that one. Kinda important one to.
BTW Bill, checks in the mail. Wintertime's here, I need 10 ply gripers. I'll worry about balancing when you bring'her back....but while 'ya washing & detailing her out, could you look under the back seat?? I've lost my wallet. "Mad money" in the back, under the flap where I keep the food stamps.....help your self, OK? Doubt you have time to start my "LuckyMod", I'll do it on this end.
Dipstick: You boys talking about automatic dipstick I think. Big problem with new bends in tube with flat dipstick! This is different, but when I was adding & deleating stuff under my hood, I needed to move my engine oil dipstick. Ended with different tube or something, bent all kinds of angles. Was really hard to keep from ruining tube from kinks & new bends. I needed longer & more flexable stick. I looked for bigger older speedometer cable to braze onto handle, but couldn't find one (used to use this kind on the semi's) Finally rummaged thru local Ford's boneyard obsolete sticks. Found some long one from an auto-tran. Changed oil, remarked at my 11qt & 12qt marks. Then still had to carefully grind down the sides about 3/4 of length & make a "streamlined" point on end of stick. Stick's lot narrower than original. Took about 3-4 trys to get it to slide better around the new tweaks & bends. Also took a whet-rock & file to the sides several times & smoothed burrs, that helped lots.
Turbo downpipe joint That joint of mine has always leaked at startup for close to a minuite till warmed up & expand, & you'd think it be easy to slip apart. I've fought that thing, squirted stuff, beat on it, wiggled it, said "dirtyword, dirtyword, dirtyword" so many times I'm ashamed. Then other times I get all psyched-up, mad, mean, then start the project.....& the d**n thing fall apart. "Scaried it apart", I guess???
Shop A/C & pretty shop pics Mine is AC'ed too. Sun was shinning yesterday so I started to take some pic & learn how to post'm to OB. But I got into a dilemma....couldn't figure which side to start shooting first. Has no walls, no roof, doors, nor floor...but she's A/C'ed!!!
Wifey makes me "do it" out past, even past the backyard, out in the pasture! Ex cords & such run everywhere!!! Ya get the Pic??
But Warden, I don't have to worry about next door lawyers like you. We "live on the other side of the tracks."
I been eyeballing the garage where she parks her car....I could knock the wall out, then drive part way into the living room to mechanic work! Be closer to the TV...no lost time....turn wrenches & watch "Oprah, Days of Our Lives, Turning Worlds, Dr Phill"
Somethings up with the wifey though....she said something about "not liking the last nearly 34 yr of my oil, grease, & of allthings,junk & not planning to change now!!!" I don't know....beats me!
