Got factory turbo!!
RLDSL
Diesel fuel abuser
Arkansas
I may have a factory oil line down in the shop somewhere. If I can find the thing, you're welcome to it.
I've got mine rigged up with a chunk of -06 Aeroquip hose.
----Robert
Jake S.
clueless...
Taylors Falls, MN
The banks pics are the same as my ATS. Factory turbo blocks get it from the sender port, but they are 1/4 pipe for more flow.
Dirtleg
Cloverdale VA
Thanks for the offer RLDSL. I don't want to sound ungrateful but I don't like to reuse things like the oil line. Scares me. Plus I don't have the factory oil manifold thing that bolts to the turbo oil inlet so I'm probably just looking at a custom line from the hydraulic shop.
I climbed under my truck today and noticed oil on the filter. It's coming from either the oil pan or oil cooler so it looks like I'll be taking something apart down there. While I am at it I might as well tap the oil filter head for the oil line.
1/8 pipe by -4 jic 90 degree elbow on the block down by the slave , same for the turbo but 1/4 pipe. 32-33 inch long teflon stainless braided line. Make damn sure you CLEAN out that oil galley before you put the new fitting in, it holds goo and WILL wipe out your turbo. Preoil the turbo. The orings are pretty standard at a hydraulic shop, get brown ones for the heat resistance if you can. Not mandatory but helps.
Dirtleg
Cloverdale VA
Thanks for the fitting and hose info type4. I think I have a 1/4 x either 45 or JIC in my fittings collection already. I'll have to check it. The main reason I am thinking about the filter head for the oil is the fact that the oil galley is certainly gooed up on my engine. If I do decide to clean it what's the correct method? Small bottle brush and then crank (not start)the motor with the plug out?
FordGuy100
Silverton, OR
Thats basically what I did. I used a bore cleaner of some sort that was in our tool box, bent the handle so that I could get some leverage on it, then shoved it in there. The first time it seriously took me 10 minutes to get it out, there was so much crap in therer. I had to twist it out. I then cleaned it off in a can full of clean diesel, then did it a couple more times.
What Justin said, and liberal amounts of brakleen or carb cleaner.
oldmisterbill
Grumpy Old Man
Wagoner Oklahoma
This is my oil feed line-I just had to make sure it was well supported in rubber gromets to prevent vibration-cost lesss than $10.00.I used 3/8 line for better oil flow-poured oil in top of turbo before I put the line on for prelube.
Dirtleg
Cloverdale VA
Thanks for the pictures Bill. I always like to get a look at something before attempting to tackle it.
