crash-harris
Breaker! Breaker!
Yay factory numbers!
Ford Sterling 10.25/10.5
1.50" axle shaft dia. 35 splines
Mfg. Output Torque Rating:
10.25 8300 ft.lbs. short duration/2000 ft. lbs continuous, gross axle wt. rating 8250 lbs.
10.5 10,660 ft. lbs short duration/2900 ft. lbs continuous, gross axle wt. rating 9750 lbs
AAM 11.50 Gen.II 14 Bolt
1.43" axle shaft dia. 30 splines
8333 ft. lbs. GM application, gross axle wt. rating 6500 lbs SRW GM application
GM 10.50 Rear 14 Bolt
1.50 axle shaft dia. 30 splines
6242 ft. lbs. (max), gross axle wt. rating 5700-8600 lbs.
The above information is taken directly from my differential "bible", Differentials, Identification, Restoration and Repair by Jim Allen and Randy Lyman.
as opposed to offer mine.
So what makes the sterling that much "stronger"? is it the 35spline vs 30spline? Doesnt make much sense.
FORD thing
other than going for a deep swim with the truck and not changing the oils afterwards, would you kill a D70. if you have FF14bolts sitting around doing nothing, put them on CL and sell them for $$$.It's not that I need a rear end, I just have 3 14blts at the moment and was curious if I should hand onto one or not. I really dont think my na 6.9 is going to do any damage to my D70 any time soon, but ya never know!
had to dig into a 10.5, not a 10.25, so i have a biased opinion lol
I'm with him on this. Like I mentioned, we're replacing a Sterling with a D70. The axle weight rating was actually higher on the Dana than the Sterling, by 200 lbs IIRC. I suspect that has to do with the springs more than anything else, but still, point is that it's no weak axle by any means. Make some money off what you don't really need, fund something else on the truck that actually could use an upgrade.other than going for a deep swim with the truck and not changing the oils afterwards, would you kill a D70. if you have FF14bolts sitting around doing nothing, put them on CL and sell them for $$$.
that would be what I would do.
Thank you ALL for the info an opinions. I think I will sell the 14blts and use that money for a ZF-5!
