Glow plug problem
fireman624
My 6.9L seems to keep melting the end off of the glow plug inthe #7 cylinder(right side rear cyl).Any ideas on why this one cylinder keeps melting plugs? Tryed some Autolites,and Champions I had laying around here.(New Motorcrafts will be in hand tomorow A.M.) But I really don't want to install one in the #7 if it's gona melt.Changed out the injector on #7 today don't know if it'll help or not.
Exekiel69
The answer could be right there, because you are using the wrong type/quality glow plugs. Beru/motorcraft are best and should not melt. Beru you can get them at $8-$10 a piece at autozone or online (evilbay) as I did.
Russ
Idont do injectors
New Brighton PA
Bingo!!! Like EZ said put the Berus in and toss the Autolites as far as you can. Or the next time you'll be pulling the heads off to get the melted/burnt off tip out of the piston.
Cv axle
