DeepRoots
Tug Engineer
just double checking with those in the know.
45mph for me is at 2,000rpms
60 mph is roughly 2,5000rpms
top speed is like 72-73mph or so
235/85/16 tires, c6trans
seems like I would have 4.10gears, ya?
door jam, and tag on the diff says 3.55
previous owner must have changed it.
most of the driving here in southern Ga is highway, where folks are doing 75mph so I was thinking I may change the gears, I'm tired of running the truck at 2,800rpms.
I use this truck for work, rarely hauling a trailer (maybe 1/12 of the time mileage wise) and the load is rarely over 4-5k lbs.
Mostly running empty with my tools, and jobsite supplies. Truck weights 5,900lbs empty (I run it lean) and typically 7,500-8k lbs loaded for a job.
is there anything wrong with using 3.08 gears? It would kill my desire for an overdrive (which I can't afford anyway).
I figure whenever I rebuild the c6 I can use the lower first two gears and make it a 'wide ratio' c6
my old f150 had 2.73 gears and it ran fine, just a lil slow from the start. are these 3.08 gears going to really kill the trucks ability to run?
there are very few hills here, and as I said, I'm not hauling a house, nor am I entering into any races in the near future
thanks in advance,
Drew
thanks in advance,
Drew
