Fuel pressure
9779scott
Bear Creek, Wi
The truck has 232000 not sure of any replacements of anything. Was told thing were acouple years old but not true. So NO idea. I put a gauge on the schrader valve and going down the road and have about 4 psi give or take. At idle it has a bounces about a quarter pound. Should I replace the mechanical or put on electric? What psi should go to the IP?
ford390gashog
brentwood
The pump should make 5-7 psi .25 at idle seems low but if it runs okay then I would assume its fine. Its really the flow you need not so much pressure.
Diesel JD
Gainesville, FL
The down the road psi isn't too bad but it really should be minimum of 4 psi at all times. Personally I like the e-pumps but there's nothing wrong with the mechanical pump either. I'd replace it assuming your fuel filter is recent and you have no obvious pressure side leaks.
mitsu tractor
