Fuel and water Sep.
Silentnoise
Hamilton/ohio
Hey guys and gals got a question. On top of my fuel and water Sep. It has a black rubber looks like censor and its letting a lot of fuel out from under it. Is there a way to tighten it? How do you get it off? Also looks like between the filter and housing it comes out a little too. Is the filter just bad and need replaced? Any help is wanted losing a lot of fuel.
w4dsb
loganville ga
its the fuel heater connection , you have to remove the filter head then the inside unscrews and you can get to the connector. it has a o ring on it.
thx997303
utah
I changed mine without removing the filter head. I just removed the filter and unscrewed everything from there. It's a pretty easy thing to do.
w4dsb
loganville ga
i like that approach.....i had mine off already so i could look inside and find out where the leak was :)
crewchief219
Wichita, KS
I did this a few weeks ago and used this link to help me do it. There are actually two o-rings and I learned that the hard way and had to take it back apart. The second o-ring is "hidden" inside the fuel heater itself. This write-up does a good job explaining it.
http://www.oilburners.net/forums/showthread.php?46363-Fuel-heater-O-ring-replacement"]http://www.oilburners.net/forums/showthread.php?46363-Fuel-heater-O-ring-replacement[/URL]
thx997303
utah
Keep in mind you can get o-rings that will work from places other than IH and ford.
I happened to have a viton o-ring assortment, so I used one of them. These same o rings wouldn't work on my return line caps, but this one is presses into a tapered cone, so it's a little less sensitive to perfect OEM fit than the return line caps.
crewchief219
Wichita, KS
Here's another link. This has some really good pictures. If it looks like this, there are two o-rings to change. One you will see as soon as you remove the heater. The other o-ring is inside the heater. To access it, you unclip the plastic shell from the metal and push the electric spade through the hole it sticks out of. I didn't know about the second one until I'd put it all back together and it still leaked.. :/ Hope this helps!
http://www.ford-trucks.com/forums/859602-fuel-heater-fix-directions-w-pics.html
Sgtbyersfw
